jimmys Posted July 16, 2007 Share Posted July 16, 2007 I had wiring problem with my car it had "R" light lit on dash and won't shift. I took out instrument cluster to find problem. Later I was able to fix that problem with great help from this forum. Now the air bag light came on after that. I hooked up everything back as it suppose to be. Is there a way to reset that light? Quote Link to comment Share on other sites More sharing options...
RFeldes Posted July 16, 2007 Share Posted July 16, 2007 I had wiring problem with my car it had "R" light lit on dash and won't shift. I took out instrument cluster to find problem. Later I was able to fix that problem with great help from this forum. Now the air bag light came on after that. I hooked up everything back as it suppose to be. Is there a way to reset that light? Try this thread.............. http://us.lexusownersclub.com/forums/index...setting+airbags Quote Link to comment Share on other sites More sharing options...
dflint Posted November 12, 2007 Share Posted November 12, 2007 I had wiring problem with my car it had "R" light lit on dash and won't shift. I took out instrument cluster to find problem. Later I was able to fix that problem with great help from this forum. Now the air bag light came on after that. I hooked up everything back as it suppose to be. Is there a way to reset that light? It worked for my 94 LS 400, thanks for the tip. The light came on after re-installing my instrument cluster Quote Link to comment Share on other sites More sharing options...
91LexusLS400 Posted November 13, 2007 Share Posted November 13, 2007 Had to replace my odometer 2 years ago, air bag light came on after removing/replacing cluster. The wire 'dance' worked, not more air bag light. Quote Link to comment Share on other sites More sharing options...
