36R Posted September 3, 2003 Share Posted September 3, 2003 Hi Everyone, I just got a 96 ES300 with 76k, ant not working. So I pulled the old mast out, but there's no cable attached, I supposed it stuck inside. Can someone tell me how to reach the ant motor and take the motor apart to remove the cable? Thanks a bunch. Alex Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 3, 2003 Share Posted September 3, 2003 you will have to open up the whole assembly to get the plastic mast out which mean removing it from the trunk also if you retract the broken mast there is still no plastic? you might want to try and use the ant removing procedure to get the inner mast out it it has just disconected from it but you will still need a new mast Quote Link to comment Share on other sites More sharing options...
