anitafagina Posted July 4, 2007 Share Posted July 4, 2007 I recently notice a few address on my LS430 isn't showing up like it supposed to on my RX350. After inquiring with dealership, they said it will cost me $450 for the disc and $89 for the install. I own both vehicles and both discs. Is there a way to backup the RX350 nav disc and use it on my LS? Will Alcohol 120/double-layer dvd disc combination work for backing up the DVD? Thanks, Anita. Quote Link to comment Share on other sites More sharing options...
tonystewart Posted July 4, 2007 Share Posted July 4, 2007 2007 RX350 is a Generation 5 dvd http://www.lexus-parts.com/partlist.asp?Su...amp;ModelID=161 2004 LS430 is a Generation 4 dvd http://www.lexus-parts.com/partlist.asp?Su...amp;ModelID=105 They are not interchangeable. As you can see from the links the price for the disc is $299. You install it yourself, less than 10 minutes, and save yourself a bit of cash and avoid the "stealership". Backups can be made but I would only recommend the following media: Verbatim 8X DVD+R DL. It is the "only" consistently reliable media that works in new and older Lexus Navigation systems. Believe this to be fact. Cheers! Quote Link to comment Share on other sites More sharing options...
anitafagina Posted July 4, 2007 Author Share Posted July 4, 2007 2007 RX350 is a Generation 5 dvd http://www.lexus-parts.com/partlist.asp?Su...amp;ModelID=1612004 LS430 is a Generation 4 dvd http://www.lexus-parts.com/partlist.asp?Su...amp;ModelID=105 They are not interchangeable. Thanks for the info. The price for both disc are the same. As you can see from the links the price for the disc is $299. You install it yourself, less than 10 minutes, and save yourself a bit of cash and avoid the "stealership". LOL "stealership", I want to do it myself...is there a install CD or just some on-screen display button sequence that I need to follow to install the Generation5 DVD? Can you please point me to the right direction? Backups can be made but I would only recommend the following media: Verbatim 8X DVD+R DL. It is the "only" consistently reliable media that works in new and older Lexus Navigation systems. Believe this to be fact.Cheers! I do want to following the facts. I have some SONY DVD+R DL "AccuCORE", but I can go out and get some Verbatim as you described. What sort of program did you use? (assuming you did this before successfully) Will Alcohol 120% work? Or did you use some other software? Thanks again. Anita Quote Link to comment Share on other sites More sharing options...
