Is 350 Washing Issues
Hello!!
Let me tell you what I have done for the past two and only washes on my car. I purchased some car soap basically, mixes with water.
1) I rinse the car from top to bottom, everywhere.
2) I start at the top of the car and soap the top
3) I then proceed to soap the hood, door panels, and back.
4) I last do the front & back bumpers
At this point, I proceed to rinse the car again and make sure I have rinsed everything. Lastly, I take my shami and dry off the car with any spots of water I see.
My questions are:
1) Am I doing this horribly wrong??
2) I notice I still see spots on my car after the drying, how can I dry this properly?
3) (maybe associated with 2) but, I can never get my shami super dry, I ring it out like crazy, but when I wipe it on the car, it still leaves water, I got to the point where its pretty dry, but damn, I dunno.
4) My windows are bad with the water spots too.
Anyone have any suggestions? I am looking for some help, my car gets sorda clean, at least all the visible dirt is gone, but I see water spots if I look really close. One problem, I'm only 1 person, so by the time I rinse the car, and dry one area, I go to the next and the water's already gone!!
This is my first attempts at washing cars, I have never done it before so any suggestions will help, maybe more shami's, maybe different drying materials, maybe I'm washing wrong.
Thanks for any help!
Jeff.
I would rinse each area as you wash it instead of soaping the entire car and then rinsing. That may be part of your spotting problem.
I personally don't like chamois, I prefer waffle weave microfiber for drying. What type of wash mitt are you using?
Wash mitt? I am using a big soft sponge to basically apply the soap, I use a mitt only to wash the rims which work good. Should I use a mitt to apply the soap?
Also, what about drying, is there anything other than a shami I could use, cause I just can't seem to figure out how they work, because it just seems to spread the water not really dry the car.
thanks!
Jeff.
He's referring to Microfiber waffle-weave towels for drying. Superior softness and absorbsion--available locally, and online. (You get what you pay for)
Perhaps spraying each panel with a quick-detailer before you dry--this should help remove any new spotting on the spot, and provide some lubricity for your drying medium.
Good luck!
What type of sponge is it? Nothing wrong with a sponge, what matters is the material its made out of.
Yep, I'd try a microfiber waffle weave drying towel. I reccomend www.pakshak.com but there are other good merchants as well. I think your issue is two fold, one you probably have pretty hard water, two you're leaving behind water as the chamois wipes by.
Thanks guys so far for your help. I am going tommorrow and see what cleaning supplies a local napa has, or maybe I'll try another auto place. I'd rather not order, but if I dont get anything this weekend, I will order stuff for next weekends cleaning :)
By the way, you said I have pretty hard water, what do you mean by that? I get water from the hose, and I put that on spray so it's not full blasting on the car. If that's what you meant. Also, I know I might be leaving water behind with the chamois wipes, I will DEFINATELY get a microfiber waffle weave towel, If nothing else, that will help dry this thing much better.
One more question, what about the windows, is there a special way to clean the outside OR inside of the windows? I just use the same soap on the panels on the windows, is there any special window cleaner I can get?
thanks
Jeff.
SW-am a newbie!just purchased a 05' RX330 any suggestions for general routine exterior cleaning?pls give me a list of products-u sound like a wealth of knowledge on detailing.also have a few minor paint chips on the hood-any suggestions?thanks
Sadly enough you really have no choice but to order. The best products are not available in local stores.
Water only spots when it has a mineral content to it, the water evaporates and the minerals are left behind on the paint which causes a spot. "Hard water" refers to water that has a large concentration of minerals in it and spots easily.
I use Stoner's Invisible Glass
Hey Rah, I got your PM too. Look around on here for some products to use, I and others have discussed so many of them any list I would give you would be incomplete.
As for the chips, really no choice but to touch those up.
  • 1 month later...
I have used the Mr. Clean car wash kit for several years. I don't like the soap but the filtered final rinse water gets rid of water spots...the filter lasts about 7-10 washes. No need to squegee or wipe down. Consumer Reports tried it and gave it a good report.
Speaking of water spots...
has anyone ever installed one of these?
Or, how bout one of these???
It's a lot of money, but if it works....
