lsrxlex Posted June 18, 2007 Share Posted June 18, 2007 Hi all, I used 409 and a soft toothbrush to clean the black fiberglass liner of the hood, but I didn't get a good clean. Besides, the fiberglass was easy to catch lints. Any ideas how to clean it correctly? Thanks. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 18, 2007 Share Posted June 18, 2007 Thats hard, in fact I would venture to say its impossible to clean without making it fall apart... Quote Link to comment Share on other sites More sharing options...
TOGWT Posted June 21, 2007 Share Posted June 21, 2007 B) If the underside of the engine compartment hood has a sound deadening felt-like cover- •Brush the cover with a soft brush, using light pressure to avoid tearing the material •Using a soft brush attachment, vacuum the surface using a very light pressure •Spray P21S® Total Auto Wash on to a 100% cotton terry towel •Use very light and even pressure on the towel (use a ‘patting’ type motion, do not rub the lining as it may tear) •Work the cleaner into the fabric but do not saturate the material or use much pressure on the towel •Fill a spray bottle with clean water and rinse area thoroughly •Using a terry towel gently blot the surface, rinsing the towel often until all residue is removed Quote Link to comment Share on other sites More sharing options...
