How Do You Set Seat Memory?
trkfxer
Seat position memory (if equipped)
Your preferred front passenger seat position can be entered into the computer's memory and recalled with the touch of a button. Three different seat positions can be entered into memory.
Entering a position to memory
Vehicles with an automatic transmission: Check that the shift lever is set in P.
Vehicles with a manual transmission: Check that the parking brake is set.
STEP1Switch to IG-ON mode.
STEP2Adjust the front passenger seat to the desired position.
STEP3While pushing the SET button,
push button 1, 2 or 3 until the signal beeps.If the selected button has already been preset, the previously recorded position will be overwritten.
Recalling the memorized position
Vehicles with a manual transmission: Check that the parking brake isset.
Push button 1, 2 or 3 to recall
Retained accessory power
Memorized position can be activated up to 30 seconds after the front passenger
door is opened, even after turning the engine switch OFF.
To cancel seat position recall
Perform any of the following operations.
Push the SET button.
Push button 1, 2, or 3.
Adjust the seat position using the switches.
If the battery is disconnected
The memorized positions must be reset because the computer's memory is erased
when the battery is disconnected.
