trkfxer Posted May 30, 2007 Share Posted May 30, 2007 i have a 06 430 had to put a new batt now seat memory dont work how do i do it?? Quote Link to comment Share on other sites More sharing options...
cuda Posted May 30, 2007 Share Posted May 30, 2007 Seat position memory (if equipped) Your preferred front passenger seat position can be entered into the computer's memory and recalled with the touch of a button. Three different seat positions can be entered into memory. Entering a position to memory Vehicles with an automatic transmission: Check that the shift lever is set in P. Vehicles with a manual transmission: Check that the parking brake is set. STEP1Switch to IG-ON mode. STEP2Adjust the front passenger seat to the desired position. STEP3While pushing the SET button, push button 1, 2 or 3 until the signal beeps.If the selected button has already been preset, the previously recorded position will be overwritten. Recalling the memorized position Vehicles with an automatic transmission: Check that the shift lever is set in P. Vehicles with a manual transmission: Check that the parking brake isset. Push button 1, 2 or 3 to recall the desired position. Retained accessory power Memorized position can be activated up to 30 seconds after the front passenger door is opened, even after turning the engine switch OFF. To cancel seat position recall Perform any of the following operations. Push the SET button. Push button 1, 2, or 3. Adjust the seat position using the switches. If the battery is disconnected The memorized positions must be reset because the computer's memory is erased when the battery is disconnected. Quote Link to comment Share on other sites More sharing options...
