Heater Hoses
Hello,
My car is '97 ES300 and car has 248,600 miles. I did replaced radiator upper and bottom hose last year.
I did inspected heater hoses, looks normal.
I am going to flush radiator next weekend, Should i replace heater hoses?
Clean Temp. RTD.
Thanks in advance.
Hello,
Clean Temp. RTD.
Thanks in advance.
Probably not.........Change the thermostat :cheers:
that car has definately lived its lifetime..damn 250k miles...im at 154, and i drive an average of 6-8k miles a year, i'd have this car for a long time if it lasts as long as yours, what kind of other problems have you encountered since you've had the vehicle?
Lower arm control bushing, Struts, stabelizer bar bushing, Engine mounts.
Try to clean MAF, endup buying new. not needed but error code 0150 so change both O2 sensor.
before O2 change, Avg was 28 MPG with new O2 sensor didn't make any differance.
Other then that it's running good.
Every 5000 oil change every 15000 miles trans. oil change with PCV and gromet and air filter.
3-4 years battery, brakes.
I don't know how to stop this car so i can buy NEW.
Thanks,
