Power Steering Filter?
Found this post and it intrigued me to find this. "cleaning the filter in the power steering solenoid control valve and in the fluid reservoir will help avoid system leaks and power steering pump failures. The lower ball joints, transmission mounts and suspension bushings won't be badly worn if the prior owners weren't aggresive, hard charging drivers. The failing liquid crystal displays in the dashboard can be repaired by independent specialists familiar with the problem, etc."
Where do I find this exactly? I have a feeling mine is dirty/bad.
