The manual is quite clear on how to do it but...
How easy it is to remove the plastic covers on the top of the engine?
I want to move my headlights just a little bit up, but do not want to mess with removing and re-installing the plastic covers if it is not a super easy task. Any comments?
Thanks
if you look on the cover, you will see where the pins are. Just push on the center of hte pins and i assume it will just pop up and release. lol
You just push the little buttons down on the fastners and they should pop right out. Take the front one off first. On the side one, there is one fastener inboard near the battery that you have to turn like a little nut till it's loose and then pop the cover off. The original fasteners are kinda easy to bend or break. I replaced mine with some stronger ones I got at NAPA.
