dopefishzzz Posted May 4, 2007 Share Posted May 4, 2007 Hi ! I've got a 94 ES300 with 200,000 miles on it. Air filtter and fuel filter have been changed recently. When accelerating under WOT (Wide Open Throttle), the car hesitate, only between 3000rpm and 4000rpm. Below & Above, I get normal acceleration. When I say hesitate, I mean that the car lose about half of it's power, but still has enough to go pass the 4000rpm mark. Gas mileage is fine and I've got no check engine light. Engine runs smooth, no strange noise and no shaking. What could be the problem ? (Note that I have a small exhaust leak, just behind the muffler, could It be affecting THAT much ?) Thank you. Quote Link to comment Share on other sites More sharing options...
wwest Posted May 4, 2007 Share Posted May 4, 2007 Hi !I've got a 94 ES300 with 200,000 miles on it. Air filtter and fuel filter have been changed recently. When accelerating under WOT (Wide Open Throttle), the car hesitate, only between 3000rpm and 4000rpm. Below & Above, I get normal acceleration. When I say hesitate, I mean that the car lose about half of it's power, but still has enough to go pass the 4000rpm mark. Gas mileage is fine and I've got no check engine light. Engine runs smooth, no strange noise and no shaking. What could be the problem ? (Note that I have a small exhaust leak, just behind the muffler, could It be affecting THAT much ?) Thank you. Might be somewhat SOP at 200,000 miles... Valve float due to weakened valve springs, slight backfire, etc. Quote Link to comment Share on other sites More sharing options...
dopefishzzz Posted May 4, 2007 Author Share Posted May 4, 2007 Then why would the engine runs great at a much higher RPM ? Power is great at 5000rpm, 6000rpm etc.. Doesn't make sense to me, but I'm no expert at all. Quote Link to comment Share on other sites More sharing options...
wwest Posted May 4, 2007 Share Posted May 4, 2007 Then why would the engine runs great at a much higher RPM ? Power is great at 5000rpm, 6000rpm etc..Doesn't make sense to me, but I'm no expert at all. Many cars have two springs on each valve, a heavy one and a lighter one inside of that. I cannot explain the engineering aspects, I just assume it takes both springs to cover the wide range of frequency, 500 to 6000 RPM, of valve opening and closing operation. I could see how one spring might begin to allow the valve to float, say at 4000 RPM, before the second, lighter(??) spring comes into "play". Many years ago I would have suggested a valve job, but at today's labor rates and with 200,000 miles.... Quote Link to comment Share on other sites More sharing options...
dopefishzzz Posted May 7, 2007 Author Share Posted May 7, 2007 Then why would the engine runs great at a much higher RPM ? Power is great at 5000rpm, 6000rpm etc..Doesn't make sense to me, but I'm no expert at all. Many cars have two springs on each valve, a heavy one and a lighter one inside of that. I cannot explain the engineering aspects, I just assume it takes both springs to cover the wide range of frequency, 500 to 6000 RPM, of valve opening and closing operation. I could see how one spring might begin to allow the valve to float, say at 4000 RPM, before the second, lighter(??) spring comes into "play". Many years ago I would have suggested a valve job, but at today's labor rates and with 200,000 miles.... Do you think a compression check would reveal if you are right ? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 7, 2007 Share Posted May 7, 2007 check for an egr problem as it open around that range. Quote Link to comment Share on other sites More sharing options...
dopefishzzz Posted May 9, 2007 Author Share Posted May 9, 2007 Thanks for the tips, but wouldn't an EGR problem cause the check engine light to turn on ? Quote Link to comment Share on other sites More sharing options...
dopefishzzz Posted May 16, 2007 Author Share Posted May 16, 2007 Compression check done. Nothing unusual. Quote Link to comment Share on other sites More sharing options...
vetmx1 Posted May 19, 2007 Share Posted May 19, 2007 I have a '00 that has a hesitation with a pop/backfire. You're in the gas a little, let off, and immediately press it to the floor. Runs fine otherwise. Quote Link to comment Share on other sites More sharing options...
wwest Posted May 20, 2007 Share Posted May 20, 2007 I have a '00 that has a hesitation with a pop/backfire.You're in the gas a little, let off, and immediately press it to the floor. Runs fine otherwise. Sure sign of burning/leaking intake valve(s), you need a valve job. Quote Link to comment Share on other sites More sharing options...
