lexlover1 Posted April 29, 2007 Share Posted April 29, 2007 Can somebody please tell me how to reset the abs light on a 93 es. I know I have saw it on here before but can't find it again thanks. Quote Link to comment Share on other sites More sharing options...
homemechanic Posted April 29, 2007 Share Posted April 29, 2007 Can somebody please tell me how to reset the abs light on a 93 es. I know I have saw it on here before but can't find it again thanks. Let's take a step back. How did you end up with this problem? Did you do anything to cause this problem? ABS light doesn't just pop up unless there is a problem. Quote Link to comment Share on other sites More sharing options...
lexlover1 Posted April 29, 2007 Author Share Posted April 29, 2007 Can somebody please tell me how to reset the abs light on a 93 es. I know I have saw it on here before but can't find it again thanks. Let's take a step back. How did you end up with this problem? Did you do anything to cause this problem? ABS light doesn't just pop up unless there is a problem. Replaced the abs wheel sensor, now I need to reset the light since unhooking the power don't reset it. Quote Link to comment Share on other sites More sharing options...
leert12 Posted June 30, 2007 Share Posted June 30, 2007 Can somebody please tell me how to reset the abs light on a 93 es. I know I have saw it on here before but can't find it again thanks. Let's take a step back. How did you end up with this problem? Did you do anything to cause this problem? ABS light doesn't just pop up unless there is a problem. Replaced the abs wheel sensor, now I need to reset the light since unhooking the power don't reset it. I think you might not be able to reset it yourself, try AutoZone and ask them if they can do it. If not, you might have to take it to the dealer. Unless there's a sequence to follow to reset it. I'd be interested to find out also. Quote Link to comment Share on other sites More sharing options...
norbertk Posted July 5, 2007 Share Posted July 5, 2007 Try pulling your 15A EFI fuse for 10 or more seconds. If that doesn't work I'll go digging in the factory manual Quote Link to comment Share on other sites More sharing options...
