Cracked Key Shell
unfortunately, i have a 93. Am I screwed?
http://cgi.ebay.com/92-93-94-95-96-LEXUS-E...1QQcmdZViewItem
You can use just the plastic case without getting another key cut. Just open the case on the new one and cut away the plastic holding the blank key and it will come right out, Do the same with your key, Then carefully epoxy the old key shaft into the new case. Doin't forget to put a new battery in.
