Boots Posted April 24, 2007 Share Posted April 24, 2007 So here's my problem. I have an '01 IS and one of my dash lights is out. Well on top of that, I think I have a loose connection somewhere behind the dash in the vicinity of the speedo. Long story short, sometimes none of my gauge/dash lights come on with the headlights, and when this happens, my tail lights don't function either. The brake lights work fine. It was intermittent but has decided to stick around constantly the past 5 days. The fact that it came and went, along with a bump in the road now and then leads me to think it's a loose connection or a bad ground. So any way, does anyone have experience with taking apart the dash and accessing the area behind the gauges? Any info would be GREATLY appreciated. Quote Link to comment Share on other sites More sharing options...
Parking17 Posted April 25, 2007 Share Posted April 25, 2007 These two links should help. http://my.is/forums/go-faster/233511-how-r...rac-lights.html http://my.is/forums/inside-out/291397-tuto...ge-cluster.html Quote Link to comment Share on other sites More sharing options...
SunnyD Posted September 2, 2007 Share Posted September 2, 2007 So here's my problem. I have an '01 IS and one of my dash lights is out. Well on top of that, I think I have a loose connection somewhere behind the dash in the vicinity of the speedo. Long story short, sometimes none of my gauge/dash lights come on with the headlights, and when this happens, my tail lights don't function either. The brake lights work fine. It was intermittent but has decided to stick around constantly the past 5 days. The fact that it came and went, along with a bump in the road now and then leads me to think it's a loose connection or a bad ground. So any way, does anyone have experience with taking apart the dash and accessing the area behind the gauges? Any info would be GREATLY appreciated. ......Im currently having this same problem, did u figure out wut was happening? Quote Link to comment Share on other sites More sharing options...
Parking17 Posted September 14, 2007 Share Posted September 14, 2007 Looks like the links I supplied earlier in this post are no longer valid. Check your fuses first, located by the drivers left foot. Consult your owners manual for fuse location. If that doesn't help, then the plug behind the dimmer knob is probably loose. It completes the circuit, so if it is loose, you will not have dash lights at all. Quote Link to comment Share on other sites More sharing options...
