Shebco Posted April 10, 2007 Share Posted April 10, 2007 The latest firmware upgrade from Verizon (1.05) has fixed the bugs that kept it from working fully on Bluetooth in my RX400h. Call waiting disconnect was the main fix. Quote Link to comment Share on other sites More sharing options...
w@ntonsoup Posted April 23, 2007 Share Posted April 23, 2007 The latest firmware upgrade from Verizon (1.05) has fixed the bugs that kept it from working fully on Bluetooth in my RX400h. Call waiting disconnect was the main fix. I did the firmware upgrade but still won't connect. What is the call waiting disconnect you mentioned? Quote Link to comment Share on other sites More sharing options...
katzjamr Posted April 24, 2007 Share Posted April 24, 2007 There is a known issue with the 650 and the Lexus bluetooth system. It will connect and work, however during the initial connection process you will NOT get a screen that says connection successful. After going through all the proceedures correctly, simply make a phone call and it will pair with the lexus bluetooth. Quote Link to comment Share on other sites More sharing options...
Shebco Posted May 5, 2007 Author Share Posted May 5, 2007 There is a known issue with the 650 and the Lexus bluetooth system. It will connect and work, however during the initial connection process you will NOT get a screen that says connection successful. After going through all the proceedures correctly, simply make a phone call and it will pair with the lexus bluetooth. The bug was that whenever a second call came in using BT on the Lexus it would disconnect both calls making the whole thing useless. V 1.05 has fixed this and I now use the Lexus BT over my headset with no problems. My only other 'wish list' item now would be to able to use the telephone menu items while driving. Even using the 'bypass' trick it doesn't allow you to input or search any phone book entries or dial a number from the dash. It's no big deal really as I can use the phone to do that but it would be nice. Quote Link to comment Share on other sites More sharing options...
