How Do I Reset The Ecu For A 94 Gs300
I added a new intake,So ive heard its good to reset the ECU,Also Im having a problem,My door open symbol is turned on in my car,even tho Passenger side door is closed. The light that turns on when that door is open is also on,But the door is clearly shut. But mainly I'd Like to know how to reset it.
  • 4 weeks later...
There is an EFI (electronic fuel injection) system fuse in a black fuse box underneath the hood. I think it is a 20amp red fuse. The fuse names are marked on the inside of the box lid. You need to turn off your car take this fuse out for more than 10 seconds and put it back into its slot. This will reset your ECM. If you turn on the car now it would have reset all the logged (Intermittent) faults but if there is any active fault left it will still show up on your dash CEL/MIL.
