Largest Wheel/tire Combo W/drop And No Camber Problems?
Help a noob. What's the biggest you can go on a 2.5" drop and being able to effectively correct the camber? I've searched everywhere and am not really finding anything out. I am currently running 20"s, I love them but the tires a sooooo expensive and they do not last more then 6-7k. Any camber correction and I'm afraid I would get some rubbing. Thanks in advance.
I gained about an additional 3/4" of sidewall clearance. I'm not sure how the wheel liners in your car is set-up, but you might have to cut or remove the liners to roll for fenders flat.
I rolled the fenders myself, with a baseball bat and a heat gun. Just make sure that the paint is properly heated, before rolling the fenders and it shouldn't crack.
