rrr Posted February 23, 2007 Share Posted February 23, 2007 I have a 2006 GS300 RWD, and it's time for an oil change. I've always changed my own oil, but this car's filter looks very different. I understand it's a canister type of filter, but the replacement filter came with a plastic connector like thing to apparently drain the oil filter before removing it (?) Does anyone have instructions on doing this? Is there a special tool involved? There is a cap on the filter that looks like it could unscrew, but looks like a special tool is needed to do it... Any help appreciated! Quote Link to comment Share on other sites More sharing options...
RPrindl Posted April 23, 2007 Share Posted April 23, 2007 I like the new filter setup, reminds me of a motorcycle filter. Just remove that little cap, find a hose for the plastic thing and you will drain the oil from the filter. See pictures. Quote Link to comment Share on other sites More sharing options...
RPrindl Posted April 23, 2007 Share Posted April 23, 2007 Then use a standard filter wrench to open up the filter housing. Changing the oil on these cars isn't the messey job it used to be! Quote Link to comment Share on other sites More sharing options...
dave702 Posted July 22, 2008 Share Posted July 22, 2008 I like the new filter setup, reminds me of a motorcycle filter. Just remove that little cap, find a hose for the plastic thing and you will drain the oil from the filter. See pictures. what kind of tool do u use to pull the drain plug Quote Link to comment Share on other sites More sharing options...
steviej Posted July 22, 2008 Share Posted July 22, 2008 what kind of tool do u use to pull the drain plug are you talking about the drain plug in the oil pan? If so, a 14mm socket on a breaker bar works best. if you are talking about the plastic drain thingy that you insert into the bottom of the oil filter canister, you push it to the side until it snaps. It will then fall off in two pieces. You get a new thingy with the new filter cartridge. steviej Quote Link to comment Share on other sites More sharing options...
dave702 Posted July 22, 2008 Share Posted July 22, 2008 I like the new filter setup, reminds me of a motorcycle filter. Just remove that little cap, find a hose for the plastic thing and you will drain the oil from the filter. See pictures. what kind of tool do u use to pull the drain plug i im talking the one where u drain the oil from Quote Link to comment Share on other sites More sharing options...
steviej Posted July 23, 2008 Share Posted July 23, 2008 i im talking the one where u drain the oil from Dave, you still have not answered my question. You have to drain the oil from TWO places, so here is a quick procedure. First: There is a plug in the bottom of the oil pan, that must come out and over 6 qts or oil will drain into your collection pan. This takes a 14mm or 17mm socket to remove it (I forgot which at the moment). Be sure to reinstall the plug with a new crush washer before putting in the new oil. The old crush washer can be reused successfully a couple of times if you don't have a new one. Second: You should drain the oil from the oil cartridge cannister before dropping the cannister to replace the actual cartridge. Use a socket on the small molded nut at the end of the cannister. Remove the end cap and discard the old O-ring. Toyota and aftermarket filters come with new O-rings. There is a plastic hose adapter that comes with the new fitler. Attach a short length of old garden hose to it and then shove the other end of the plastic adapter into the now open recepticle at the bottom of the oil filter cannister. There is a spring loaded valve that this plastic spout pushes open. The small quantitiy of oil in remaining in the cannister will now drain out. Once this is done, just push the plastic spout to the side. It will snap and break, thus falling out of the hole. Put the new O-ring on the end cap and screw it back in, tighten with socker. Be careful, not too tight as this cannister is alluminum and very soft. You can strip it easily. Now using the proper size cap wrench a strap wrench, remove the larger section of cannister and discard the larger O-ring. Remove the old filter, place in the new one, remove the old large O-ring and put on the new one. Screw the cannister back into the housing. I hope that answers your question. steviej Quote Link to comment Share on other sites More sharing options...
simplyadditions Posted May 7, 2011 Share Posted May 7, 2011 I have a 2006 GS300 RWD, and it's time for an oil change. I've always changed my own oil, but this car's filter looks very different. I understand it's a canister type of filter, but the replacement filter came with a plastic connector like thing to apparently drain the oil filter before removing it (?) Does anyone have instructions on doing this? Is there a special tool involved? There is a cap on the filter that looks like it could unscrew, but looks like a special tool is needed to do it... Any help appreciated! I just made a video on how to do the oil change on the Lexus using the instructions I found on this forum. Thanks Guys! Quote Link to comment Share on other sites More sharing options...
quizex Posted June 16, 2011 Share Posted June 16, 2011 I have a 2006 GS300 RWD, and it's time for an oil change. I've always changed my own oil, but this car's filter looks very different. I understand it's a canister type of filter, but the replacement filter came with a plastic connector like thing to apparently drain the oil filter before removing it (?) Does anyone have instructions on doing this? Is there a special tool involved? There is a cap on the filter that looks like it could unscrew, but looks like a special tool is needed to do it... Any help appreciated! Very nice DIY! Personally I never use the plastic small piece to drain oil from the filter - to me its just an extra step, I just remove the canister and drain all oil all together Quote Link to comment Share on other sites More sharing options...
Raja2006gs Posted March 31, 2012 Share Posted March 31, 2012 I have a 2006 GS300 RWD, and I do not have the nut on the end. I recently purchased this vehicle, and I decided to change the oil myself because after I had the oil changed at the dealer, I noticed that they overfilled the oil and it looked dirty. I was surprised that my vehicle did not have the nut on the end of the filter. anyway I read somewhere that the GS350 did not have the nut, and you have to align the tabs on the canister body to drain the oil from the filter. I used a regular filter wrench and successfully changed my oil. I am now using Castrol Edge syn, and it is at the right level and clean. Quote Link to comment Share on other sites More sharing options...
peterharvey73 Posted April 7, 2012 Share Posted April 7, 2012 There is no nut at the end of the canister. So yes, you have to buy an SST Special Service Tool from Lexus to remove the oil filter. Only costs about $20-30. Or you can buy an aftermarket SST to remove the oil filter, but be sure to get the right size though... In this last photo, the SST tool is seen grasping the oil filter cannister... Quote Link to comment Share on other sites More sharing options...
