Ray92es Posted February 21, 2007 Share Posted February 21, 2007 I just found out that one of my fuel lines running under the driver seat has rusted through. Has anyone ever replaced these? Does anyone know what size the tubing is? That protective plastic cover seems to be a moisture trap causing leaks. I had to replace a brake line last year. Quote Link to comment Share on other sites More sharing options...
Ray92es Posted February 27, 2007 Author Share Posted February 27, 2007 I just found out that one of my fuel lines running under the driver seat has rusted through. Has anyone ever replaced these? Does anyone know what size the tubing is? That protective plastic cover seems to be a moisture trap causing leaks. I had to replace a brake line last year. Purchased new tube from dealer, They run over $40 ea but I don't want to go through manualy bending the tubing in the winter. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 27, 2007 Share Posted February 27, 2007 Next time mention what year the car is . It is normal for a ES 300 92-93 seem to rust the brake and fuel lines if it is not regularly cleaned and rustproofed. It is usually much cheaper to bend your own lines to replace damaged ones and is rather simple to fabricate with a tool kit. Quote Link to comment Share on other sites More sharing options...
Ray92es Posted February 28, 2007 Author Share Posted February 28, 2007 Next time mention what year the car is . It is normal for a ES 300 92-93 seem to rust the brake and fuel lines if it is not regularly cleaned and rustproofed. It is usually much cheaper to bend your own lines to replace damaged ones and is rather simple to fabricate with a tool kit. I did the rear brake line by hand as you have to remove the rear axle assembly to put in a preformed pipe. It would not be cheaper to do the fuel line if you add the cost of frostbite working on a car in the snow. I bug people too about stating pertinent info about their car all the time but I though my moniker, Ray92es, gave it away. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted February 28, 2007 Share Posted February 28, 2007 spend a little more money... don't you think your fingers are worth it? Quote Link to comment Share on other sites More sharing options...
