watersport202 Posted August 21, 2003 Share Posted August 21, 2003 My Lexus Premium Sound AMFM Cassette (with CD Changer in Glovebox) displays fine for the first 5-10 minutes of operation. Gradually some of the pixels start to gray out or dissappear. Has anyone else seen this problem? Is this more likely a bulb issue, a ribbon cable connector, or a bad LCD panel? If so, is it hard to get to to and to fix this problem? Thank you in advance for any light you can shed for this do-it-yourselfer. Quote Link to comment Share on other sites More sharing options...
SpeedRacer959 Posted August 21, 2003 Share Posted August 21, 2003 Had the same problem. You need a new head unit. I bought one on ebay, but you can easily find them at www.car-part.com for cheap too. You're probably looking at a $75-$100 fix for that. -Jimi Quote Link to comment Share on other sites More sharing options...
SpeedRacer959 Posted August 21, 2003 Share Posted August 21, 2003 To make it clearer, it's the LCD panel that's bad. If you get a new unit, you can take the LCD panel out of the new unit and swap them, but it's just as easy to swap the whole head unit. Also, taking the head unit out is tricky, but easy when you know how. There's detailed instructions (with pictures) on the LOC board somewhere for removing it. Good luck, Jimi Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 22, 2003 Share Posted August 22, 2003 i have the same problem with my climate control but rpessing it in jjust the right spot brings it back it is basiccally a bad connection Quote Link to comment Share on other sites More sharing options...
MCV20 Posted August 22, 2003 Share Posted August 22, 2003 i had it on mine it was common problem on ES (dealer told me)... dealer fix/change it for me....with a refrubish one... or just change out the head unit(other brand)... :chairshot: Quote Link to comment Share on other sites More sharing options...
johnc Posted January 14, 2004 Share Posted January 14, 2004 To make it clearer, it's the LCD panel that's bad. If you get a new unit, you can take the LCD panel out of the new unit and swap them, but it's just as easy to swap the whole head unit.Also, taking the head unit out is tricky, but easy when you know how. There's detailed instructions (with pictures) on the LOC board somewhere for removing it. Good luck, Jimi If I get a new (used) Lexus head unit, won't I run into the bad display problem again soon. Is there a way to just purchase and replace the LCD with a brand new LCD Panel? Anyone know where to get a new LCD Panel? If I need to cannibalize an LCD panel from another Lexus head unit are they all the same. Will the LCD panel from and Lexus head unit fit the head unit in my 97 ES300? Thanks, John Quote Link to comment Share on other sites More sharing options...
poppabear Posted February 24, 2004 Share Posted February 24, 2004 I just got a replacement LCD display from David at: jill allen [dabaysidejill01@worldnet.att.net] for $125. It came with complete instructions for removing the head unit. I was quoted $270 to replace the LCD from a radio repair shop. They also quoted $60 to replace if I provide the parts. The instructions seem simple, but I don't have the right tool to pop out the AC vent. I plan on having the repair shop do the repair. Quote Link to comment Share on other sites More sharing options...
