scotty2hottyoki Posted January 31, 2007 Share Posted January 31, 2007 I have a 93 lexus ls400...does this car have two throttle position sensors? if not...what is the other sensor right next to the throttle position sensor and what does it do? thanks Quote Link to comment Share on other sites More sharing options...
mehullica Posted February 1, 2007 Share Posted February 1, 2007 The one closest to the engine is the TPS, the other one near the plastic intake tube is for the TRAC system. Quote Link to comment Share on other sites More sharing options...
scotty2hottyoki Posted February 1, 2007 Author Share Posted February 1, 2007 The one closest to the engine is the TPS, the other one near the plastic intake tube is for the TRAC system. Thanks mehullica Quote Link to comment Share on other sites More sharing options...
rtd111 Posted February 20, 2007 Share Posted February 20, 2007 91 LS400, 155K miles. Any ideas how to test or adjust the TRAC sensor referred to in the above post? I cleaned out my throttle body today. The plan actually was to replace the TPS (one closer to the engine), because of TRAC light and code 41. But while I was at it, I decided to clean the TB. Used a whole can of the cleaner stuff. Quite a mess. Anyways, the TB is nice and shiny now. Began to put the new TPS (part #89452-22090 per LexLs Tutorial). If I adjust the TPS per the tutorial, the engine revs at over 3K. Tried several times and RPMs would jump around between 1.8K to over 3K. I wasn't sure if this was due to mis-setting of the TPS or the TRAC sensor. So I put my old TPS (part #89452-12050) back in. And I put both sensors in WITHOUT engaging the "metal prongs" that control the valve, and that got the RPM down to a more reasonable 750. I drove the car around a bit and it drives as it always did (maybe a little easier because of the clean TB :P ). Any ideas on how to adjust these two sensors? I can retry the TPS using the lexls tutorial but need assistance on the TRAC. BTW, the TRAC light remains on now right from when I start the the engine. Previously, it would come on after driving a few miles. Haven't rechecked the code lately. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
fencera Posted May 28, 2007 Share Posted May 28, 2007 I second this. Does anyone know how to adjust the TRAC sensor? Although my TRAC light is not on, there is an audible clicking noise whenever I turn the key to the ACC position that was not there before I cleaned the throttle body (and stupidly removed the two sensors). Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
fencera Posted May 30, 2007 Share Posted May 30, 2007 Anyone have any ideas? It is a rather ominous clicking noise everytime I start the car. Quote Link to comment Share on other sites More sharing options...
Moarpower Posted July 13, 2017 Share Posted July 13, 2017 I know this is an old thread but I thought I would resolve it as I had the issue myself and found no answer on the forums. If you hear a loud ticking from the TB area and you have trac mounted to the throttle body, there is a good chance that your traction pot is out of alignment. If the part is not broken it is an easy fix. TO diagnose that this is your ticking, disconnect the cable a the rear of the TB, not the 2 o n the pots, the one connected towards the cabin, just above the plastic airflow assembly. Set the ignition to on and see if the ticking is gone. If it is, you need to realign the trac pot Quote Link to comment Share on other sites More sharing options...
jppettis Posted December 7, 2019 Share Posted December 7, 2019 What do you mean by TRAC pot? How would I go about aligning this? I am also getting the clicking noise and I need to know how to fix it. Quote Link to comment Share on other sites More sharing options...
jppettis Posted December 7, 2019 Share Posted December 7, 2019 On 7/12/2017 at 10:35 PM, Moarpower said: I know this is an old thread but I thought I would resolve it as I had the issue myself and found no answer on the forums. If you hear a loud ticking from the TB area and you have trac mounted to the throttle body, there is a good chance that your traction pot is out of alignment. If the part is not broken it is an easy fix. TO diagnose that this is your ticking, disconnect the cable a the rear of the TB, not the 2 o n the pots, the one connected towards the cabin, just above the plastic airflow assembly. Set the ignition to on and see if the ticking is gone. If it is, you need to realign the trac pot This is what I am replying to, sorry. Quote Link to comment Share on other sites More sharing options...
