Shayan Posted January 17, 2007 Share Posted January 17, 2007 Hello, I have a 1992 es300 with 169000 Miles on it, and i spend every one of my pay checks on that car. It makes a lemon look good.(LOL) This morning when i was turning, The steering wheel kept spinning 360 degrees, when i turned, You know how theres a point where the tires cant go no further and your steering wheel stops turning, well mine just kept going in circles. Is that my steering rack? And this afternoon about 10 hours later after that happend, its catching now and working normal, but it screeches when i turn it. Any help or suggestions would help. Thanks. Shayan G. Quote Link to comment Share on other sites More sharing options...
92Lex Posted January 17, 2007 Share Posted January 17, 2007 Wheel should of stopped but was there wheel heavy when you spun it? Quote Link to comment Share on other sites More sharing options...
Shayan Posted January 17, 2007 Author Share Posted January 17, 2007 Wheel should of stopped but was there wheel heavy when you spun it? The first turn of the day i took the wheel wouldent turn almost as if the car was off and then when it did turn, it just kept spinning. Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted January 17, 2007 Share Posted January 17, 2007 Do your wheel turn at all when you turn the steering wheel? Check the linkage between the steering rack pinion and the steering wheel shaft in the engine bay. Quote Link to comment Share on other sites More sharing options...
Shayan Posted January 18, 2007 Author Share Posted January 18, 2007 Do your wheel turn at all when you turn the steering wheel? Check the linkage between the steering rack pinion and the steering wheel shaft in the engine bay. Yes, The wheel does turn and when it turns it screeches and clicks almost like a cv joint sound, but my cv joints are new so it cant be that. Quote Link to comment Share on other sites More sharing options...
