Streering Wheel Won't Go Up And Down
 Share
I did the same thing but with a metal washer from true value hardware. That is a good article and should work as long as the motor didn't give out. Do you hear the motor running when you try to move it up and down? If you do, this should work. Its a common problem and the gear gets out of sync with the screw attached to the motor causing them not to connect.
 Share
