Location Of 97 Ls 400 Amplifier
Penquins'97LS400
should be under you front passenger seat under the plastic vent cover.
Thanks I found it! I was doing some searching on remote starts and I see you have a clifford installed in your 98' who did the install? Did you have to have a 2nd key hidden behind the dashboard? Best Buy told me I would need a 2nd key to do the install. I'm wondering if there is some way to bypass this issue and/or use the factory key fob to use with a remote start system. i saw a post that said he used the same fob and hit the panic button twice. Do you have any info? Thanks!!!
Has Anyone ever used this module in their 97 LS 400? http://www.caraudio-caralarms.com/555X.html I just want the perfect setup for remote starting and not too many people are doing this in the 97'...
your key does not have a chip in it so you dont have to worry about hiding another key in the car
i have a remote start from compustar for few years now in my ls and it works just fine:)
