coleycoleman1906 Posted December 4, 2006 Posted December 4, 2006 i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice!
coleycoleman1906 Posted December 4, 2006 Author Posted December 4, 2006 All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice!
dcfish Posted December 4, 2006 Posted December 4, 2006 All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Easy trigger, Someone will post with the info you seek. Sometimes it takes a little while to get a response. http://us.lexusownersclub.com/forums/index.php?showuser=744 should be able to help you out on this matter.
coleycoleman1906 Posted December 4, 2006 Author Posted December 4, 2006 Sorry im just going thru 2 quarts a day, and tearing up the parking lot All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Easy trigger, Someone will post with the info you seek. Sometimes it takes a little while to get a response. http://us.lexusownersclub.com/forums/index.php?showuser=744 should be able to help you out on this matter.
SKperformance Posted December 5, 2006 Posted December 5, 2006 You need to clean the area where the the metal crush washer goes othewise it will keep cutting the alumiunum washer and keep leaking. So buy a new oem toyota washer and clean all 4 surfaces.
