coleycoleman1906 Posted December 4, 2006 Share Posted December 4, 2006 i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Quote Link to comment Share on other sites More sharing options...
coleycoleman1906 Posted December 4, 2006 Author Share Posted December 4, 2006 All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 4, 2006 Share Posted December 4, 2006 All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Easy trigger, Someone will post with the info you seek. Sometimes it takes a little while to get a response. http://us.lexusownersclub.com/forums/index.php?showuser=744 should be able to help you out on this matter. Quote Link to comment Share on other sites More sharing options...
coleycoleman1906 Posted December 4, 2006 Author Share Posted December 4, 2006 Sorry im just going thru 2 quarts a day, and tearing up the parking lot All, Do i need a torque wrench or something, cause i tightened as tight as i could, didnt want to strip the bolt!? any comment will be greatly appreciated i need ed to drain the dirty fluid, on my 97 es300 so i removed a screw with a hose on it to fix it , yes the fluid came running out of the pump and the resevoir, but now no matter how hard i tighnten this #4 screw, it leaks from that screw, ive tried 2 washers and everything. Thanks for any advice! Easy trigger, Someone will post with the info you seek. Sometimes it takes a little while to get a response. http://us.lexusownersclub.com/forums/index.php?showuser=744 should be able to help you out on this matter. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 5, 2006 Share Posted December 5, 2006 You need to clean the area where the the metal crush washer goes othewise it will keep cutting the alumiunum washer and keep leaking. So buy a new oem toyota washer and clean all 4 surfaces. Quote Link to comment Share on other sites More sharing options...
