Backup Camera
A week or so a go I had this problem. As I was backing up my IS into the garage, I noticed that the backup camera did not come up. It just showed the regular Map on the the screen. I then put the car into the P position then shifted to R again then the backup camera came up as normal. Had anyone ever experienced this? So far this was the only incident! Thanks all!
ah! my wife yells at me when this happens because its usually my fault. If someone (or you) is doing soemthing, like changing the airconditioning settigns or other settings using the buttons, putting the car into reverse will not give you the backup camera because it will not interupt what your doing.
try to remember if you were playing around with the other settings
