sternern Posted August 16, 2003 Share Posted August 16, 2003 does any know if the navigation head unit for the 99 GS400 will fit the 2000 Gs300? does it integrate easily? Please let me know, I found a kick !Removed! deal. What also is part of the nav system....cd rom, any other parts to the unit itself? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 16, 2003 Share Posted August 16, 2003 It'll fit, but the install is very involved and requires a lot of custom wiring. The nav should consist of the: -Head unit -Hard Drive -Antenna -Wiring harness It also has a vehicle maintenance deal and a trip computer. LOTS of wiring, I think it was estimated at 24 hours of labor. Its been done though. Quote Link to comment Share on other sites More sharing options...
mrsebastian Posted August 17, 2003 Share Posted August 17, 2003 if you can find a good deal, i'd definitely pick it up. it'll certainly add more value to your gs. i'd go talk to your lex dealer and see how much they'd charge to install as they'll be able to do it right. keep us posted, as it's something i've been thinking about doing as well. Quote Link to comment Share on other sites More sharing options...
slammedgs400 Posted August 17, 2003 Share Posted August 17, 2003 how much do those systems go for complete? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 17, 2003 Share Posted August 17, 2003 The Lexus dealer would either: 1: Refuse to touch it 2: Or charge you something with 4 digits. Quote Link to comment Share on other sites More sharing options...
bbsal Posted August 17, 2003 Share Posted August 17, 2003 i agree the lexus dealer would probably not touch it.if they did it would cost a small fortune. Quote Link to comment Share on other sites More sharing options...
z2die4 Posted August 17, 2003 Share Posted August 17, 2003 Also, dont forget speed sensor computer, speed sensor itself. You might run into audio issues if your going from NAK to Premium or vice versa ie. amp, speaker ohm loads etc. Your better off just buying an aftermarket system. It would probably cost the same, 3k, but at least you could also play movies, have much faster mapping, and the newest software and other technology. If your capable of installing this yourself and feel comfortable removing panels and carpeting and are mechanically and electrically inclined, then go for it. Quote Link to comment Share on other sites More sharing options...
sternern Posted August 18, 2003 Author Share Posted August 18, 2003 Well, thats answers a lot of my questions...One last one...Is it worth buying the head unit for $250 anyways? Quote Link to comment Share on other sites More sharing options...
JPI Posted August 18, 2003 Share Posted August 18, 2003 You have to run all the wires through the carpet. Buy the ECU for the Nav ended up cost more than you planned. So the is "NO". JPI Quote Link to comment Share on other sites More sharing options...
