rockne Posted November 7, 2006 Posted November 7, 2006 What type bulb is used for the front turn signals? It doesn't list the type in my owners manual. I want to switch the bulbs to clear.
rockne Posted November 7, 2006 Author Posted November 7, 2006 which model Sorry, that would probably help. 2007 IS 350
bartkat Posted November 8, 2006 Posted November 8, 2006 Sylvania says. Front turn signal 992 (7440A) That's for 2006, but it's probably the same. I think there are 4 bulbs based on what I see flashing on mine. http://www.sylvania.com/ConsumerProducts/A...placementGuide/
GianniG60 Posted November 8, 2006 Posted November 8, 2006 Sylvania says. Front turn signal 992 (7440A) That's for 2006, but it's probably the same. I think there are 4 bulbs based on what I see flashing on mine. http://www.sylvania.com/ConsumerProducts/A...placementGuide/ The easiest way to answer your question is to remove the bulb from the car and bring it to the store with you to match it. Or just take it out and read on the bulb what it is. Hope this helps. - GM
bartkat Posted November 8, 2006 Posted November 8, 2006 Sylvania says. Front turn signal 992 (7440A) That's for 2006, but it's probably the same. I think there are 4 bulbs based on what I see flashing on mine. http://www.sylvania.com/ConsumerProducts/A...placementGuide/ The easiest way to answer your question is to remove the bulb from the car and bring it to the store with you to match it. Or just take it out and read on the bulb what it is. Hope this helps. - GM Easier than asking on a message board? :chairshot:
