TM8000 Posted September 24, 2006 Posted September 24, 2006 Has somebody who drives GX470 ever experienced bigger engine noise? I don't know if this noise coming from the engine or from somewhere else but my car(2003 GX470) is very quiet when I start the engine but this noise starts after I drive for a while. My experience is as follows:- After driving on highway for a while(like 20-30 miles), once stopping at the light after getting out of highway, then I hear bigger noise as if I drive in low gear when starting again though the shift changes normal. Lexus service person said it is absolutely normal and no transmission or engine problem found..... There's also a smell like something burnt only when I drive a little rough(at higher RPM). Are these things normal for 2003 GX470?
denslexusgx470 Posted September 24, 2006 Posted September 24, 2006 Yes it may sound noisy. I notice that with mine when the temp is really high either from the environment or from the engine itself. Now what is this smell? Does it smell like sulfur? Brakes? Describe where you smell it from. ;)
TM8000 Posted September 25, 2006 Author Posted September 25, 2006 Thanks for your comment, denslexusgx470. I understand that the vehicle gets noisy when the temperature gets higher, which is normal for GX470.... Smell like something burnt comes from the rear part. Lexus dealer told me that it smells when you drive up the hill by accelerating, which is also normal for this vehicle. If these two things are just normal for GX470, I have to get used to that....though these are a little bit uncomfortable.
denslexusgx470 Posted September 25, 2006 Posted September 25, 2006 Thanks for your comment, denslexusgx470. I understand that the vehicle gets noisy when the temperature gets higher, which is normal for GX470.... Smell like something burnt comes from the rear part. Lexus dealer told me that it smells when you drive up the hill by accelerating, which is also normal for this vehicle. If these two things are just normal for GX470, I have to get used to that....though these are a little bit uncomfortable. Well did you get that advice from the dealership that told you that you have a VVT-i engine in your GX but actually you don't?
TM8000 Posted September 25, 2006 Author Posted September 25, 2006 Yes. service consultant of Lexus' dealership told me so. He also told me that this is because of VVT-i though mine is 2003 which he even checked it. I am getting confused. Do you think that I should again bring my vehicle to this dealership for 1)noise and 2)smell to be checked up?
The G Man Posted September 25, 2006 Posted September 25, 2006 The smell is most likely sulfur, from un burn gasoline when accelerating hard. Wasn’t there a sulfur TSB out to change the catalytic converter. You might want to check into that. The noise you hear from the engine is most like your clutch fan, when its on, its noisy, feels like you are driving on low gear. Good Luck
TM8000 Posted September 25, 2006 Author Posted September 25, 2006 Thank you so much for your advice, The G Man! I have just received a comment from the dealer. The service consultant said that he will install a new catalyst and recalibrate to my car's ECM, which will reduce sulfur dioxide odor. He also stated that the noise seems to be coming from engine fan.... I will bring my GX470 to the dealer for a new catalyst to solve odor problem, but do I have to just get used to the noise from engine fan(clutch fan)? It sounds like so, doesn't it.
denslexusgx470 Posted September 25, 2006 Posted September 25, 2006 I knew it had to be a sulfur smell once you said it was coming from the back. I've had that happen a couple times, but mine's not "smelling" very consistently so I haven't brought it in yet. As for the sound, I'm not sure if it is normal or not.
strindl Posted September 28, 2006 Posted September 28, 2006 I recall that sulfur smell coming from the catalyst was fairly common back in the mid to late 70's when they first put those on vehicles. I havn't had that problem on any of my vehicles since then though. I thought that was gone for good.
The G Man Posted September 28, 2006 Posted September 28, 2006 With the lower EPA sulfur standard for gasoline, that surfur smell should be a thing of the pass pretty soon.
TM8000 Posted September 28, 2006 Author Posted September 28, 2006 Thank you for all of your comments. I still have not receive a call from Lexus dealership for a new Catalyst. Also, updated driveshaft is a loooong back order... They said that my name is on their list and all I have to do is just to wait for these parts......
