OfnaJoe Posted September 18, 2006 Share Posted September 18, 2006 I am a Newbie to Lexus and this board, So glad to be here and really glad to have a Lexus. Even if it is used! I just bought a 2002 IS 300 and was wondering about the small light bulb in the low beam headlight reflector. How do you get it to come on? Thanks in advance, Joe Quote Link to comment Share on other sites More sharing options...
steviej Posted September 19, 2006 Share Posted September 19, 2006 I would make a guess that they were the bulbs for the DRL (daytime running lights). On the light stalk, see if there is a DRL position or an AUTO position. If so, twist the switch to that. Then start the car and put it in R or D and while stepping on the brake, have someone go see if those bulbs light up. When in doubt, read the manaul. If you don't have a manual, log into www.lexus.com, go to the owners section, register, and request a free one. steviej Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 19, 2006 Share Posted September 19, 2006 Those may be the parking lights. Turn the light switch stalk one click and see if they come on. It also may be an extra turn signal bulb. Play around with it till you find out. The DRL is the high beam bulbs with power reduced through a resistor. They come on whenever the engine is on and the headlights are off. Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted September 19, 2006 Share Posted September 19, 2006 i haven ever seen them on at all, but i will check the next time i drive it Quote Link to comment Share on other sites More sharing options...
OfnaJoe Posted September 19, 2006 Author Share Posted September 19, 2006 Thanks guys Quote Link to comment Share on other sites More sharing options...
steviej Posted September 20, 2006 Share Posted September 20, 2006 The DRL is the high beam bulbs with power reduced through a resistor. They come on whenever the engine is on and the headlights are off. Thanks for the clarification. I know the ES runs that way, I wasn't sure if the IS did too. As I remember, the older generation GS had these bulbs too. steviej Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 20, 2006 Share Posted September 20, 2006 The DRL is the high beam bulbs with power reduced through a resistor. They come on whenever the engine is on and the headlights are off. Thanks for the clarification. I know the ES runs that way, I wasn't sure if the IS did too. As I remember, the older generation GS had these bulbs too. steviej 2nd gen IS has separate bulbs for DRL. Quote Link to comment Share on other sites More sharing options...
OfnaJoe Posted September 20, 2006 Author Share Posted September 20, 2006 Mine uses the low beam at reduced voltage. Have tried eveerything to get the small bulb to come on but it won't. Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 20, 2006 Share Posted September 20, 2006 Mine uses the low beam at reduced voltage. Have tried eveerything to get the small bulb to come on but it won't. Are you sure that's not the high beams for DRL? The low beams are HID. Quote Link to comment Share on other sites More sharing options...
OfnaJoe Posted September 20, 2006 Author Share Posted September 20, 2006 DUH! I was thinking high and typed low. Yes it is highbeam for DRL Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted September 21, 2006 Share Posted September 21, 2006 okay i found out what it does. when you turn on the regular headlights, they come on as well. lol thats it Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 21, 2006 Share Posted September 21, 2006 Near as I can tell from the parts diagram, they're "clearance" lights. ? Quote Link to comment Share on other sites More sharing options...
OfnaJoe Posted September 23, 2006 Author Share Posted September 23, 2006 Near as I can tell from the parts diagram, they're "clearance" lights. ? clearance for what? If you look at this months Modified magizine with Jeff Wilson's IS 300 in it his little light is on! Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 24, 2006 Share Posted September 24, 2006 Near as I can tell from the parts diagram, they're "clearance" lights. ? clearance for what? If you look at this months Modified magizine with Jeff Wilson's IS 300 in it his little light is on! Bulb, Clearance Lamp, PART # 00234-00192 Otherwise known as parking lights. http://us.lexusownersclub.com/forums/index...ost&id=4038 Quote Link to comment Share on other sites More sharing options...
OfnaJoe Posted September 24, 2006 Author Share Posted September 24, 2006 YIPEE!!!!!!! Thanks everybody. I got them working, One was loose connection, and the other was blown. I thought only the side marker lights was park lights. Thanks to bartkat's link I found out different. Thanks again, Joe Quote Link to comment Share on other sites More sharing options...
