My mechanic stated that my broken air/fuel sensor located in the front of the engine is not a problem. I just wanted to get a second opinion.
sramnari:
by ???, I think sk is asking what do you mean by air/fuel sensor. If not, then I am asking.
perhaps your mechanic means the oxygen sensor that is located in the front bank?
the O2 sensor does play a part in air/fuel mixture calculations.
Why do you think it is broken, is/was the check engine light on and the code retreived indicating a bad O2 sensor?
steviej
Ok, thanks stevie. My check engine&trac off light came on. The lights go on and off. I had a mechanic check out the code which came up as p 1133. :rolleyes: On the computer print out it comes up as the air/fuel sensor. Is there not such a sensor or is it also referred to as O2 sensor of which I know there is three.
It is indeed your bank 1 sensor 1. This sensor located by the firewall on the exhuast manifold. Here is a little quick tip;
Bank 1 the one in the back: Cylinders 1, 3 and 5
Bank 2 the one in the front: Cylinders 2, 4 and 6
All of the toyota V6 are the same way. Have a good day.
JPI
