Anyone have any experience with disc brake squealing.
My wife's '97 ES300 brakes squeal when coming to the last few feet of a stop, only when mild pressure is applied.
No squealing when heavy pressure, or at higher speeds, only just before the car comes to a stop.
Pads are only about 20% worn and the wear indicators are not touching (not that kind of a sound anyway).
Tried spraying everything with brake cleaner, no help.
I told her that this is probably normal as they are probably semi-metallic pads clamping a steel rotor.
She still doesn't like it.
Only other thing I can do is pull the pads and put some disc brake "quiet" type lubricant between the pad and the piston.
If you roll to a stop light with your window rolled down, you notice many other car brakes squeal to a certain degree anyway.
Anyone want to help get my wife off my back? :chairshot:
Jeff Hauck
Gresham, OR.
I own a 97 ES300 that had squealing brakes. I took it in for service and the mechanic told me that the shims were the cause of the squeal. Since my brake pads were >40% worn, i had the pads and the shims replaced. Now my car is as quiet as when i bought it. Verify that the shims are the cause of the squeal, then get them replaced.
shims usually don't need to be replaced as tehy are only a small peice of metal
that receive no wear or movements
the pads may have glazed causing the noise though
