About Brake System..
projzxr
I was driving to the mall when I stepped on the brakes and all of sudden it felt like there was no fluid. I went outside to look around and I noticed that brake fluid was leaking along the driver side right underneath the car inbetween the driverside door and rear driver side door. I noticed their were like brake fluid lines running right along the car. Everytime I stepped on it fluid was leaking right out. I was wondering if somebody has had this issue. Or how much or what would I need to replace. Just trying to get an idea. By the way I drive a 90' es250. Thanks in advance.
It should be a metal pipe/tubing alone that spot which leads me to belive you have a rusty car which has caused the lines to rupture.
The whole brake line will need to be made and rebent from the front to the back . It is not cheap but still cheaper than buying a OEM prebent one from toyota.
