branlday Posted August 17, 2006 Share Posted August 17, 2006 While working in my engine compartment I found a wire that either I bumped loose or was already loose. The problem is that I can't find a female plug for it anywhere. It is two yellow wires with a white connector coming out of the main wire conduit that runs along the rear valve cover. It is not the wire that connects to the rear O2 sensor. Someone here must know where this wire goes! Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted August 17, 2006 Share Posted August 17, 2006 While working in my engine compartment I found a wire that either I bumped loose or was already loose. The problem is that I can't find a female plug for it anywhere. It is two yellow wires with a white connector coming out of the main wire conduit that runs along the rear valve cover. It is not the wire that connects to the rear O2 sensor. Someone here must know where this wire goes! Looks a bit like the jack to the variable speed valve in the steering pininon. Quote Link to comment Share on other sites More sharing options...
branlday Posted August 18, 2006 Author Share Posted August 18, 2006 Thanks xxxavier2k! I could not find "variable speed valve" in the FSM but you did help me narrow down my search. I focused on the Steering pinion area and found a socket (with my hand not my eyes) that the wire fit. The great thing is that this wire appears to be the wire that communicates with the fan soloniod to tell the cooling fan to speed up. My car has always run one tick above the middle of the temp guage, but after I bumped this wire loose, it kept over heating to the red, even with the AC on. After plugging this wire back in, the fan started speeding up automatically like it used to and now the guage is back to one tick above middle. Now I just need to figure out what to do to get the car running in the middle of the temp guage like it should be?? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 18, 2006 Share Posted August 18, 2006 Flush the coolant, thermostat, pressure caps & check the radiator. Normally that gets unplugged by the last person that's done a belt change. Quote Link to comment Share on other sites More sharing options...
branlday Posted August 18, 2006 Author Share Posted August 18, 2006 Will do. I already replaced the main radiator cap because it was pretty badly deteriorated but not the engine outlet cap. I also replaced the thermostat with the genuine 82 Deg C Toyota part. I found an aftermarket 78 Deg C on the car so it looks like the previous owner already tried to fix the problem. Not sure what the pressure caps are, I could not find them in the FSM. Is that another word for the radiator caps? And how do I check the radiator? I drained it to replace the thermostat and the coolant didn't have too much rust or sludge. When the car is running, the air that the fan pulls through is warm so I think it is displacing the heat like it should. Maybe it is not displacing the heat fast enough or good enough. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 18, 2006 Share Posted August 18, 2006 Probably just a different manuf's thermostat. The differance there is very minor. The Toyota thermostat begins to open at 179.6*F, that one 172.4*F. If you were trying to fix a prolbem. You'd go straight for the drop in 160*F one in my book LoL! Make sure the whole radiator is circulating coolant. Make sure it isn't clogged with debris, or has any cool spots. There's always the water pump too. Ofcorse... The coolant temps ensor could be malfunctioning & going out of spec aswell. That you can check with an ohm meter & thermometer. 13.5psi to 17.8psi - radiator The cap on the engine is 12.1psi to 16.4psi Quote Link to comment Share on other sites More sharing options...
