KatoC Posted August 2, 2006 Share Posted August 2, 2006 Have 2001 ES - wants to improve the brakes - looking for ceramic pads - any advise. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 2, 2006 Share Posted August 2, 2006 You have an 2001 ES 300 but your profile to the right says RX 300 ? Ceramic pads are going to bite more but make sure they are installed by someone qualified to install and lubricate it completely. Changing your fluid would be a better way to improve braking. Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted August 3, 2006 Share Posted August 3, 2006 Have 2001 ES - wants to improve the brakes - looking for ceramic pads - any advise. Cost of Brake Pad Set Pro-ACT Ceramic w/Shims Akebono (OEM) $59.70 Vehicle: 2001 Lexus ES 300 V6 Fits Engine - Chassis: 1MZFE — MCV20 Click here Lexus OEM Parts and Rock Auto for USA and Canada Lexus Quote Link to comment Share on other sites More sharing options...
KatoC Posted August 3, 2006 Author Share Posted August 3, 2006 That's great... May be I will get new rotors too. Is ES300 known for getting front rotor warp? Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted August 3, 2006 Share Posted August 3, 2006 That's great... May be I will get new rotors too. Is ES300 known for getting front rotor warp? Depending on how tight the lug nuts are fastened and the condition of the rotors, brake rotors may warp over time on any vehicle, not just the ES. They can also mildly warp if they undergo extreme temperature changes (e.g. cold rain or ice splashed onto the hot rotors in the winter season). Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 4, 2006 Share Posted August 4, 2006 As you are local if you want to get a nice set of brembo rotors i can get them cheap for you and even drilled . I find them equal if not better than stock rotors for much cheaper. Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted August 5, 2006 Share Posted August 5, 2006 As you are local if you want to get a nice set of brembo rotors i can get them cheap for you and even drilled . I find them equal if not better than stock rotors for much cheaper. Does anyone know if this is a good product? Lexus Brake Disc Brand: EBC Description: Front Brake Disc Set, (Set Includes 2 Rotors, One Left And One Right), Drilled And Slotted Sport Rotors, Gold, 10.8 Inch Diameter, Dimpled Hole Construction, Wider Slots Expel Gases And Stay Cooler, Gold Zinc Coated To Prevent Corrosion Year: 2000 - 2001 Engine - Chassis: Model: ES300 3.0L : 10.8" Rotor Diameter Price: $142.20 Quote Link to comment Share on other sites More sharing options...
steviej Posted August 5, 2006 Share Posted August 5, 2006 Does anyone know if this is a good product? Lexus Brake Disc Brand: EBC Description: Front Brake Disc Set, (Set Includes 2 Rotors, One Left And One Right), Drilled And Slotted Sport Rotors, Gold, 10.8 Inch Diameter, Dimpled Hole Construction, Wider Slots Expel Gases And Stay Cooler, Gold Zinc Coated To Prevent Corrosion Year: 2000 - 2001 Engine - Chassis: Model: ES300 3.0L : 10.8" Rotor Diameter Price: $142.20 I can't speak to the product, but I can vouch for EBC. Excellent brake product company, however my experience with EBC is limited to motorcycle brake products. steviej Quote Link to comment Share on other sites More sharing options...
KatoC Posted August 5, 2006 Author Share Posted August 5, 2006 Wow that sounds great, can you get them in Toronto? Also I'm looking for good Lexus mechanic... any recommendation? Quote Link to comment Share on other sites More sharing options...
