Jdm Throttle Body
Is anybody out there familiar with the parts indicated below.
I've seen pics of US es300's and thought that the only difference was the EGR fittings. But I've been having problems with the idle speed not increasing when the a/c is switched on and looked a bit closer.
The part labelled 1 seems to be some sort of sensor that works with the motor in part labelled 2 that opens and closes a valve independent of the throttle valve.
I know it's not the IAC valve nor the throttle position sensor. So what is it????
No I don't think so. The cruise control unit sat next to the battery like in US models with the accelerator cable going to it and another going to the throttle.
This sensor and motor has the valve open when the engine is off.
