Air Suspension "off" Functionality
corrado_mr2
When I disable the Air suspension (press the Off button and the dash displays it) when I'm in Park and car turned on, it re-engages (Off disappears) once I start driving. Sometimes the auto-air suspension re-engages as soon as I put it in Drive, other times it takes a few minutes of driving (irrespective of speed), but the bottom line is that it always turns back on automatically once you start driving. This always happened as I recall. I thought it should stay off and at the height set when you press the Off button...
Anyone have this working this way or can clarify this? Thanks
I think the off function is only for when you are going to have your car hoisted into the air and the wheels taken off the ground. You would not get a very good ride if your air suspension was off all the time because it could not adjust itself as you drove. It would not keep itself at the level you have set.
Tom
