xxxavier2k Posted July 9, 2006 Share Posted July 9, 2006 I just completed my engine job and decided to keep my slightly worn top (#2) idler pulley. It was making a slight noise but I figured I could live with that for a while. While driving at about 35mph the belt just up a broke!!! I'm told not to worry as my valves shouldn't be affected. Is this true? Should I change the tensioner pulley (#1)? It spins fine, has no sound when spinning but has a slight in and out play. Quote Link to comment Share on other sites More sharing options...
chips229 Posted July 9, 2006 Share Posted July 9, 2006 Hi, Myself when changing a timing belt its worth changing any pulleys that show signs of wear at the same time or all the work you have done is done for nothing if something breaks as in your case. Id put money on valve damage to your engine. Chips Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 9, 2006 Share Posted July 9, 2006 There won't be valve damage. There's nothing to cause damage. Just re-align the cams, and crank to #1 TDC. Install a belt, replacement idler pulley & think about changing the water pump, depending on it's age. (Yes replace the idler pulley, you can just buy a whole big ole kit & repalce all of them.) Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted July 10, 2006 Author Share Posted July 10, 2006 THanks for the posts guys. Is there anything else that could have caused the belt to break besides the pulley?? Bearing in mind that I got the belt, and water pump changed about 1 year ago but kept the old pulleys. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 10, 2006 Share Posted July 10, 2006 Age, shape, incorrect size, incorrect tension (dead tensioner). Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted July 13, 2006 Author Share Posted July 13, 2006 Changed the belt and upper pulley. The car is running fine. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted July 13, 2006 Author Share Posted July 13, 2006 Hi: Can a warped crankshaft pulley contribute to a broken timing belt. I just noticed that mine is warped. I 've never looked at it before so I don't know if it was warped before or as a result of the engine removal and replacement or the belt job. THere's also a sound (hissing ) from the right side of the engine bay only when the car is running. I thought it could be rust on the rotors as the car was down for a while and it rains quite a bit out here. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 14, 2006 Share Posted July 14, 2006 A hissing sound will likely be a vacuum leak, or a leak in the pre air sensor intake. AFA the crankshafts being warped. No, they're forged steel. Unless you've torched a bearing, or had a rod go funky, it shouldn't be warped. You sure it's warped, or an optical illusion? Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted July 14, 2006 Author Share Posted July 14, 2006 AFA the crankshafts being warped. No, they're forged steel. Unless you've torched a bearing, or had a rod go funky, it shouldn't be warped. You sure it's warped, or an optical illusion? Sorry, not the crankshaft itself but the pulley (that the alternator and power steering belts run on) that is keyed onto the crankshaft. THe one you have to pull off to get to the crankshaft sproket. I'll attach a video tomorrow. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 14, 2006 Share Posted July 14, 2006 Ahhhh! The core of it may be dieing. You see that alot, but you do see a thread like that crop up from time 2 time. If you just want my blind guess. :) Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted July 15, 2006 Author Share Posted July 15, 2006 Are there any rebuild options? Or can I find a new one anywhere? My online sites don't list them Quote Link to comment Share on other sites More sharing options...
Merrill Posted October 13, 2006 Share Posted October 13, 2006 the part (main crankshaft pulley ) is called a harmonic balancer. they run about a hundred bucks. mine fell apart at a stoplight. the outer ring just fell off, leaving me without an alternator or an air conditioner, but the car still drove fine. the rubber is supposed to dampen the shock placed on the crankshaft by the torque of each piston firing. the wrench required to get mine off was a huge 750 footpound impact wrench. not something found at your average home tool kit since those run more than 600 bucks. Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted October 16, 2006 Author Share Posted October 16, 2006 Thanks again for all the posts guys. I realized that I had to reset my timing belt due to high engine temps, poor performance when cold, and failure to get past 140km/h...all of this after a port n' polish, and broken timing belt. I did this about a week ago and did the afm mod along with changing the crank pulley( I used a torque handle and impact wrench socket...after breaking 3 regular sockets). THe car now runs to 160km/h very quickly and has a very aggressive launch at near to and full throttle...decent tire spin. Next on the list of mods is an improved downpipe and cat deletion. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted October 17, 2006 Share Posted October 17, 2006 Just remember that you're most likely going to be needing more fuel & not less on the AFM cog. ;) Lean is fast, but it aint good LoL! Quote Link to comment Share on other sites More sharing options...
