Rotors
ragabnh
Is there any difference between front and back rotors?
Or I have a set of front rotors, can I install it in the rear wheels?
Thanks
Thanks
The brake rotors are completely different front to back. They are different diameters, and the rear brakes have an integral brake drum for the parking brake.
Thanks
Thanks my friend.
One more question, can the rear rotors be resurfaced.
Thanks
Thanks my friend.
Yes they can. but you need to check the thickness of the rotor. If it is too warped, then you need a new rotor.
And yes.. your rear rotor is usally larger because it needs to house ur parking brake and etc;.
  • Like 1
Just buy a new set of rotors it is relatively cheap for aftermarket ones.
The rear rotors diameter is smaller but it has a larger hub to hold the parking brake . While the front one is larger diameter as it does most of the braking.
Thanks guys, great help.
