philip frank Posted July 6, 2006 Share Posted July 6, 2006 i need to replace or recover the interior trim piece that runs along the drivers side windshield pillar. (cloth covered) before i start prying on it, i wanted to see if anyone has experience with this and if i can buy a replacement piece instead of replacing the cloth covering. anyone? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted July 6, 2006 Share Posted July 6, 2006 The "A" pillar trim is MSRP $156.84. It is held to the body by clips. Pull it towards the center of the car to remove. It's easiest to start at the top. The bottom of the trim has a tab the extends below the edge of the dash. Therefore, you must release the top and tilt it out from behind the dash. Perhaps you could find a used one to replace your damaged one? Quote Link to comment Share on other sites More sharing options...
philip frank Posted August 1, 2006 Author Share Posted August 1, 2006 thanks for the info, guy. i was considering removing the part and recovering it myself perhaps. has anyone out there dealt with this type issue? i have yet to mess with it but plan to when it cools off around here. Quote Link to comment Share on other sites More sharing options...
rra640 Posted August 1, 2006 Share Posted August 1, 2006 I have the exact same issue on mine. I was going to try to find a matching fabric to see if I can recover. The damage to mine in minimal.. a portion has shrunk and is pealing away. Only I notice it, but I'd like to fix it. Quote Link to comment Share on other sites More sharing options...
