Cd Changer Not Working
I have just installed Lexus CD changer (trunk mount) in a 95 ES300. The problem is that when I close the trunk the CD player stops working and the radio comes back on. Everything works fine as long as the trunks is open, I can even bump the changer around and it plays fine until the trunk is closed (not even completely closed). Thanks,
The wiring harness in the trunk that controls the rear lights also joins up with the CD changer wiring. There might be a break in this wiring(inside the harness) that will make the radio come back on when the circuit opens......as when you jiggle the trunk door. I suggest that you remove the harness covering in the trunk and check to see that any of the wiring to the CD changer is not broken.
