Grandpa Posted July 2, 2006 Posted July 2, 2006 Well... basically, I'm onto a new problem =). Basically, whenever I shift my car into drive or park, it sort of jerks into gear and then everything else is fine... I was wondering what this could be? Also... when my car is fully heated, it idles at about 500-600 RPMS, just in case anyone was wondering
mann777 Posted July 2, 2006 Posted July 2, 2006 I had the similar problem, and I had to fine tune the TPS settings, and it was gone. cheers mann
ko90ls Posted July 2, 2006 Posted July 2, 2006 if it does that jerking in all gears check the throttle cable. there is a thread with good info if you search
Grandpa Posted July 3, 2006 Author Posted July 3, 2006 I had the similar problem, and I had to fine tune the TPS settings, and it was gone. cheers mann Could you give me some FYI on TPS and etc;? I'm totally not familiar with the engine at all. Also... I'll check to see if it jerks when I shift to different gears... I'm not 100% sure on that
mann777 Posted July 3, 2006 Posted July 3, 2006 Grandpa; "Get on the Lexls website link http://www.lexls.com/tutorials/EFI/tps.html. It is one of the easiest thing to set upon. Ensure the lexls.com method is used. I had the similar eperience, and the fear was that it could be valves detioration. And i was given this idea of reset the TPS by my garage. Thats it, it is smoothe sailing until now. cheers
Grandpa Posted July 3, 2006 Author Posted July 3, 2006 Grandpa; "Get on the Lexls website link http://www.lexls.com/tutorials/EFI/tps.html. It is one of the easiest thing to set upon. Ensure the lexls.com method is used. I had the similar eperience, and the fear was that it could be valves detioration. And i was given this idea of reset the TPS by my garage. Thats it, it is smoothe sailing until now. cheers Hrmm... from his description of the highway, I think we might be on a different page. My jerks once and it's when I shift into drive and reverse, then it'll go away.
ko90ls Posted July 3, 2006 Posted July 3, 2006 check the throttle cable. Here's a link to the thread. look for your year diagram http://us.lexusownersclub.com/forums/index...=throttle+cable
