Cygnus Posted June 11, 2006 Share Posted June 11, 2006 The Outside Temp LED on my 96 LS400 randomly changes to wierd numbers like -21 F. Sometimes it's right on the money, then out of nowhere it will change to a much lower temperature. If the A/C is running in Auto mode it seems to stop blowing cold the moment the outside temp changes to an extreme low reading. Is this a bad sensor? If so, is this an easy DIY fix? Quote Link to comment Share on other sites More sharing options...
wwest Posted June 12, 2006 Share Posted June 12, 2006 The outside temp sensor seems to be broken on my 96 es. It just shows -22 degrees. Does anyone know where the sensor is located it and how much it runs for? I can probably pick it up from a junk yard or from the dealer if I have to. Thanks Mayur Generally it's mounted behind/on the front bumper in front of the A/C condensor. -22F indicates a complete open which is more likely a broken connection or wiring. Quote Link to comment Share on other sites More sharing options...
