Door Lock Code
Arizona
I am sure this must have been asked but nothing came up in the search...
Does anyone know the code to prevent the doors from locking when the 330RX is put in gear???
Thanks
The dealer needs to program it , should be done for free.
Unless I'm mistaken, it is free if done within the first year after purchase of a new RX. Doesn't Arizona has an 04 RX?
Look in the manual--its in there how to do it, I forgot its has been a while.
A real Lexus dealer would never charge you to change settings unless you came in once a week or so......
Setting the auto door locking and unlocking
functions
You can set the following auto door locking and unlocking
functions.
a - Locking linked with the shift position
All the doors are locked automatically when the selector lever
is moved out of the “P” position with the ignition switch in the
“ON” position.*
NOTE:
* This function is the default setting for new vehicles.
b - Unlocking linked with the shift position
All the doors are unlocked automatically when the selector
lever is moved to the “P” position with the ignition switch in the
“ON” position.
c - Locking linked with the vehicle speed
All the doors are locked automatically when the vehicle speed
reaches 20 km/h (12 mph) or higher. However, if any door is
unlocked during driving, this auto locking function will not
operate until the unlocked door is opened once.
d - Unlocking linked with opening the driver’s door
All the doors are unlocked automatically when the driver’s door
is opened within 10 seconds after the ignition switch is turned
from “ON” to the “ACC” or “LOCK” position.
Setting the functions
1. Close all the doors.
2. Turn the ignition switch to the “ON” position.
3. Within 10 seconds after the ignition switch is turned to the
“ON” position;
To set function - a
Push and hold the front of the power door lock switch for 5
seconds with the selector lever in the “P” position.
To set function - b
Push and hold the rear of the power door lock switch for 5
To set function - c
seconds with the selector lever in any position except “P”.
To set function - d
All the doors automatically lock and unlock when you release
the power door lock switch. This indicates that the function is
set. If all the doors do not lock and unlock, the time the switch
was held may have been too short or too long. Perform the
procedure over again starting from step 1.
If you want to cancel a function, repeat the procedure. Each
time you perform the procedure, the function is set or
cancelled.
