speedshift Posted May 13, 2006 Share Posted May 13, 2006 1994 ES300 75,000miles The handbrake light on the dash is remaining on for me even after topping off the brake fluid. I replaced all four rotors, pads, and bled the system 4 weeks ago so I really have no idea as to what it could be. Where is the switch that activates this light on when you pull the handbrake? I'm thinking about checking that next to see if it's malfunctioning or possibly not aligned correctly. Any other ideas or suggestions appreciated! Quote Link to comment Share on other sites More sharing options...
abrarcool Posted May 13, 2006 Share Posted May 13, 2006 There is a connector at the reservoir of the brake fluid which turns on when the fluid low check its connection and remove it and check if the light goes away some times that has some problem i had it once i disconnected it and it went away reconnected after a month didnt come back Quote Link to comment Share on other sites More sharing options...
rosecityrain Posted May 14, 2006 Share Posted May 14, 2006 1994 ES300 75,000miles The handbrake light on the dash is remaining on for me even after topping off the brake fluid. I replaced all four rotors, pads, and bled the system 4 weeks ago so I really have no idea as to what it could be. Where is the switch that activates this light on when you pull the handbrake? I'm thinking about checking that next to see if it's malfunctioning or possibly not aligned correctly. Any other ideas or suggestions appreciated! If I'm guessing correctly, this is the red icon with the car with "rays" coming out the back, right? If I open my trunk and move the wires where the CD player is supposed to be (mine isn't there anymore) this stops. If an umbrella in the trunk or anything else in there contacts these wires, it turns this light on on the dash. That's all it takes for me to turn that light off. Rosie Quote Link to comment Share on other sites More sharing options...
speedshift Posted May 14, 2006 Author Share Posted May 14, 2006 Thanks for the replies but it seems to have fixed itself. It wasn't the taillight out indicator, it was the one that says "Brake" spelled out, for the emergency handbrake. Quote Link to comment Share on other sites More sharing options...
94LexusES Posted November 28, 2006 Share Posted November 28, 2006 I'm glad i searched this topic. The "BRAKE" light has been on, (right next to the check engine light ugh). It seems to go off when i hit a bump or recently I put the car in neutral as i was moving and slammed the brakes. But shortly after it comes back on. I'm trading the car in maybe this Saturday so i need to get it off. I also have a check engine light, anyway to get that light off for the time being? I can't afford to fix the car to actually get the light off at the moment. I've done things to try and get it off like a new EGR valve and such for the code "Excessive Flow", but no success. Any help? Quote Link to comment Share on other sites More sharing options...
coolwater Posted November 29, 2006 Share Posted November 29, 2006 (deleted) Quote Link to comment Share on other sites More sharing options...
94LexusES Posted November 29, 2006 Share Posted November 29, 2006 Any help? Quote Link to comment Share on other sites More sharing options...
steviej Posted December 1, 2006 Share Posted December 1, 2006 Any help? add fluid. Toyota/Lexus have very sensitive fluid level sensors. Even though the fluid level may be above the low level mark, the BRAKE light can be illuminated. Just bring the level up close to the MAX line. If it doesn't go away, then have the e-brake system looked at. steviej Quote Link to comment Share on other sites More sharing options...
Ray92es Posted December 1, 2006 Share Posted December 1, 2006 1994 ES300 75,000miles The handbrake light on the dash is remaining on for me even after topping off the brake fluid. I replaced all four rotors, pads, and bled the system 4 weeks ago so I really have no idea as to what it could be. Where is the switch that activates this light on when you pull the handbrake? I'm thinking about checking that next to see if it's malfunctioning or possibly not aligned correctly. Any other ideas or suggestions appreciated! I had the problem with my car when I parked on a steep hill. Topped off fluid and it stayed on. I remove connector from resivior and light went out. Put connector back on and light came back on. After weather got better, many many month, I decided to bleed brakes. During the process, the LR wheel cable leaked. I replaced that, not an easy job and the right one sprung a leak. Both leaks were at clamp points where the clamp hel the tubing to the body. Been fixed for over a year now. Quote Link to comment Share on other sites More sharing options...
94LexusES Posted December 1, 2006 Share Posted December 1, 2006 thanks guys. Quote Link to comment Share on other sites More sharing options...
hdygma Posted December 9, 2006 Share Posted December 9, 2006 thanks guys. I recently did a write up on DTC 0402 http://us.lexusownersclub.com/forums/index...showtopic=33746 Not sure if it helps you. It sounds like you replaced the egr (and I assume the position sensor). If not it is easy to check. If not that I would suspect the VSV. Quote Link to comment Share on other sites More sharing options...
