Blackstarr777 Posted April 28, 2006 Share Posted April 28, 2006 I was tryng to change my park lights today and i was very unsuccessful it looks like you have to remove the battery on the driver side and remove the air filter compartment on the passenger side please someone tell me this is not true because i can't get my hand down there to save my life and also what is the bulb model because it doesnt state clearly in the manual. Quote Link to comment Share on other sites More sharing options...
geoffreymg Posted April 28, 2006 Share Posted April 28, 2006 i changed mine on a 97' and all i needed was my skinny fingers. Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted April 28, 2006 Share Posted April 28, 2006 Blackstarr777, Here is a list of part numbers for the Sc300/400...If your hands aren't skinny and long enough you might have to remove the battery. As far as the passenger side it is not necessary to remove airfilter just need the skinny hands...when you remove the bulb you have to turn the casing clockwise or counter clockwise (don't remember?) to loosen and get at the actual bulb. Remember when replacing Halogen/Xenon bulb DON'T TOUCH THE BULB with your fingers or hand, it shortens the life span. Low beam: 9006 High beam: 9005 Park light :168 Front turn signal:1157a Quote Link to comment Share on other sites More sharing options...
