newbe786 Posted April 5, 2006 Share Posted April 5, 2006 I have 95' Sc400 and I'm having the strangest problem......... Can anyone please tell me why my car turns off when I turn off my A/C off. While the car is running I just push the A/C button and my car automatically turns off, its damm Weird! Any solutions would be much appreciated. I doubled checked my battery terminals to see if they were loose but everything thing looks ok. Has anyone had a similar problem like this? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 5, 2006 Share Posted April 5, 2006 Please explain what the car dieing means? Quote Link to comment Share on other sites More sharing options...
Alex-us Posted April 6, 2006 Share Posted April 6, 2006 Yes, tell us what happens. Do all the dash lights go off like you switched off the key? Or does the motor just stop, and then you get the idiot lights? Could be either: 1) A/C compressor frozen and so it just stops the engine dead 2) electrical issue w/ A/C and ignition or engine ECU Quote Link to comment Share on other sites More sharing options...
LLS Posted April 14, 2006 Share Posted April 14, 2006 The AC boots idle when it is on. When you turn it off the idle should release and drop, but not cut off obviously. The system that controls this is at fault. Quote Link to comment Share on other sites More sharing options...
Pirate Posted April 16, 2006 Share Posted April 16, 2006 I have 95' Sc400 and I'm having the strangest problem......... Can anyone please tell me why my car turns off when I turn off my A/C off. While the car is running I just push the A/C button and my car automatically turns off, its damm Weird! Any solutions would be much appreciated. I doubled checked my battery terminals to see if they were loose but everything thing looks ok. Has anyone had a similar problem like this? I have a 95' that does the same thing. If I turn off the a/c while driving the engine dies. All lights stay on etc. I can shift to neutral and re-start and as long as I have my foot on the accelerator the engine will run but if I take my foot off of the gas the engine will die again. If I park and leave the engine off for a while the car runs ok without the a/c. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 16, 2006 Share Posted April 16, 2006 Your idle up valve is jammed , clean you throttle body Quote Link to comment Share on other sites More sharing options...
mehullica Posted April 16, 2006 Share Posted April 16, 2006 SK is correct. Your throttle body is super dirty. If you remove the throttle body and look inside you should see some light pass through, the plate and body. Once carbon/deposits build-up the idle speed contol is the only thing maintaining idle speed. I have seem this on many 1995-1996 SC400's Quote Link to comment Share on other sites More sharing options...
Pirate Posted April 28, 2006 Share Posted April 28, 2006 Your idle up valve is jammed , clean you throttle body Thanks for the heads up. Cleaned throttle body---problem solved!! Quote Link to comment Share on other sites More sharing options...
