nguyen Posted April 4, 2006 Share Posted April 4, 2006 I need to find a front driver's side headlight assembly for my 95 ES300. I'm having a hard time finding one. Does anyone know if that is a Toyota part and if I could use it on my car? If so, what Toyota model and year. Or if that headlight assembly is the same for any other year ES300. Thanks! Quote Link to comment Share on other sites More sharing options...
eman_be_lexin Posted April 4, 2006 Share Posted April 4, 2006 Try eBay Quote Link to comment Share on other sites More sharing options...
Toysrme Posted April 5, 2006 Share Posted April 5, 2006 ebay, or TAPRecycling.net Quote Link to comment Share on other sites More sharing options...
nguyen Posted April 5, 2006 Author Share Posted April 5, 2006 I found a 1993 headlight assembly on Ebay. It says it should fit all ES300s from 92-96. Can anyone verify if the 93 will fit into a 95? Quote Link to comment Share on other sites More sharing options...
abrarcool Posted April 5, 2006 Share Posted April 5, 2006 No dont get the 1993 headlight for your 1995.The 1992 to 1994 have a clear reflector in the headlight and the 1995 and 1996 have a smoked black reflector in the headlight assembly also there are two strips that run on the 1995 and 1996 headlight assembly lens you'll have to get either a 1995 or 1996 year models to match or replace both to look alike Quote Link to comment Share on other sites More sharing options...
abrarcool Posted April 5, 2006 Share Posted April 5, 2006 see the difference you can buy the whole set and replace both matching or look for the ones u want there are also some toyota windom headlight assemblies that are there but i believe the low beam bulb is different on it and you might have some trouble getting it Quote Link to comment Share on other sites More sharing options...
nguyen Posted April 7, 2006 Author Share Posted April 7, 2006 Thanks for all the help so far. I looked on Ebay and saw this: ABSOLUTELY EXCELLENT CONDITION SET OF PROJECTOR HEADLIGHTS FROM A 1995 TOYOTA WINDOM HERE IN JAPAN THESE ARE FOR THE VCV10 AND VCV11 CHASSIS ES300 OR WINDOM - 1992-1996 THE WINDOM IS THE SAME EXACT CAR AS THE LEXUS ES300 - ONLY NAMED DIFFERENT FOR MARKETING PURPOSES. Can I use these to replace my 1995 ES300 headlights??? Can anyone verify this information? Quote Link to comment Share on other sites More sharing options...
