Discolor-outside Driver Side Mirror
Lexusing
Good day all.....My '96 LS400's outside power mirror has become discolor....anyone know why? How much would it cost to replace it? Where can I purchase the part and how hard is it to do it? Thanks for all your replies.....
It's behind the mirror...I think. I believe it has something to do with the Auto-dimming inside of the mirror.....It look like when you push down on an LCD screen, the chemical inside of the LCD get all over under the glass....
you can change just the mirror. i'm not sure how much itsgonna cost you, for the part, but the labor is gonna be cheap. if you want i will provide you with diagrams
IF NECESSARY, DISCONNECT MIRROR
(a) Insert the shop rag between the mirror and the mirror body to wrap up the mirror in the shop rag.
d) Disconnect the connector.
CONNECT MIRROR
(a) Connect the claws (A) and set the mirror to the mirror body.
(B) Push the mirror to connect the claws (B) and connect it.
